Tuner won't tune car cause of Po103 ?
thats what i kinda figured at idle it has no boost with the blower spinning slowly so the MAS should see vac unless you got the blower over driven like 26000 to 1 to max out the MAS lol just visualize it its like a 20inch rim to a lug nut 0 0 haha i found it found it funny
i know alot of guys around my area here the have some NASTY FI cars that are still MAS tuned not SD now granted SD is an awesome thing they say but wouldnt you rather see the air coming into the motor in real time not just estimated like the other thread said? i dont really know that much about SD but it seems like MAS is not that bad as long as you have the stock split MAS housing then tuning is easy even with HP tuners or LiveLink or a dyno tune
Necessary, no, ideal though. I'm going 3 Bar SD, no more guessing for the computer.
#33
I used to get that code on my 98 when I reved the car out with a cam only package ,up abouve 6k . I heard that its common with the 98's . I am sure the procharge will max that maf out . You need to fix it in the tune though .
But if your getting it that code at idle somethings wrong
#34
#35
That is strange, could be the tune though. You're pushing in a lot more air so if fuel isn't up to par then you'd have an issue. I'd try switching MAF's w/a buddy and see what happens. It could have just been coincidence, or maybe somehow oil from the blower/PCV got on the MAF and screwed it up.
