Finally got the vid of 9 sec pass 408 pt88 pump gas 13 psi
Race your car!
Oh that altitude/DA is retarded, hell I ran last year at atco with a 100 shot and went 9.77@ 135, DA was about -1000, Now I've taken 170 lbs out of the car and swapped a couple engine external's that should have added 10 to 15 rw and last weekend with a 2000 da couldn't even match it leaving easy.
I would ahve figured the weight and little more power would have been mroe then enough to make up for a 3000 da change, but I think even running it hard it's not going to be enough
Sean
00 Z28 | STP 408,TEA Stg2,PT88,PT A2A,HPT 3 Bar,Vic Jr.,PG,9"
As for the manufacturers of each, IDK
Eric
Oh, yeah Sean, Good Gawd thats haulin' some butt up here. Good job, man.
Tanks everyone.
Our altitude is 5600- about the same as Denver. We usually see 8-9k in DA in the summer. DA of 6k is a blessing for us lol. I would guess at 0- altitude, and a good track (mine spins after the 60 till about 660ft.), car would go maybe a .50. The trans ia Powerglide built by a local guy who has built quite a few 7 sec glides. The rear end is a mix of Moser and Strange, it is a 9" with a spool and 3.50 gear.
I do have nitrous on the car but have yet to use it. I am guessing it will go a .20 on full boost and will need 100-150 shot to put it in the 8's here. Just waiting on the 10 Pt from Wolfe then well starting putting the screws to it. All testing for our kit. Best thing is it will fit on a stock car. Maybe if we find the means to have the kit mass produced we will retail it.
