Who eliminated the STS PCV system and used a catch can?
Old 01-04-2009, 09:03 AM
  #61
shawn_c992001's Avatar
Could this be used with the STS system still in use?
Old 01-08-2009, 01:53 AM
  #62
dnm12's Avatar
well since no one has answered here (which is rare) I went ahead and just purchased PCV valves since I am trying to ventilate the crankcase
Old 01-08-2009, 12:12 PM
  #63
RooRnZ28's Avatar
you can use stock style PCV valves, but they wont totally seal and block boost from entering the crankcase. I used both the stock PCV valve and a one way check valve that i got off of ebay.
this is the one way valve i used:
check valve
just make sure you get the correct size.
as for my PCV system, no more STS valve for me. I run both rear PCV ports to a catch can and then run a line back to the turbo for constant vacuum under boost. I put a T in this line and run that to the intake manifold port for idle/part throttle vacuum. I put a check valve in this line to block off the intake manifold port when its pressurized from boost.
On the front valvecover port i run a vented catch can with a breather so that it can vent if there is any excess pressure that the turbo vacuum doesnt get. Hope this helps!
Old 01-09-2009, 02:47 AM
  #64
dnm12's Avatar
Something like this?
http://www.usplastic.com/catalog/var...ant%5Fid=64175
I have built a few setups already and every time I end up changing something as I learn
Old 01-15-2009, 07:05 PM
  #65
dnm12's Avatar
My setup (which I took from here) the white plastic are the 1-way check valve; 2 are located in line of the valve cover breathers and the other two are in the photo below:
Old 05-30-2009, 02:36 AM
  #66
blazin's Avatar
Im building up a car for a friend that already has the sts system on it and I wanna get rid of the electronic pcv or whatever it is.
On my turbo car I just ran 2 breathers on the valve covers one on each side and this seems to be effective. I have no misting,contamination or any other problems. I dont know why a sts car would be different?
Old 09-15-2009, 08:57 PM
  #67
vipvegas's Avatar
Do you really even need a breather.. If you run both valve covers to a catch can is it even necassary to have a fresh air source?
Quick Reply: Who eliminated the STS PCV system and used a catch can?
