Going To Manifolds For STS Need Help
Were are you guys getting your offroad y-pipe at that bolts to your manifolds.
Or should I just get a couple pipes made to go from my manifolds to my y-pipe I have now after I take the LT's off.
Thanks
Brad
Thanks
Brad
i have a bassani ORY that bolts up the stock manifolds, but it is not installed yet.... you should give it a looksee, as it seems like it would fit and flow pretty good. I have modified mine so that i can use v band clamps and am just waiting on my mechanic to get it installed.
when i first got it:
lol... its been in the same spot for 6 months!!
or you can spend like 50 bucks and 4hrs and build one urself .... thats what i didnt and i have no problems with it hitting or ground clearance issues and while i was at it i wraped it for my rear mount
That looks good man is it 2.5 all the way back? If so thats going to kick *** big time. I went from 3 inch to 2.5 and that made a big diffrance. But the only down side when you put manafolds and run straight through is LOUDNESS my car was way to loud and sounded like shizzle But a magnaflow bullet killed all the rasp
