Good set up fot twin turbo...
Anyone have any suggestions for a good package for a twin or single turbo running about 7lbs of boost? What cam, cat-back, intake, clutch, rear end, or anyother parts i will need ? Thanks!!
Re: Good set up fot twin turbo...
with exhaust use the most free flowing, staying away from chambered mufflers. cut outs work very well.
ls6 intake ofcoarse a ram/mcloud 6130/402 clutch will hold up good
12 bolt or 9" rear
dont forget a good tune, and supporting fuel.
for turbokits you have a CAS twin kit, incon if you can find a use one
singles are turbotech or qmp
12 bolt or 9" rear
8 second mod
Fuel and tune is the most importain. I have a spec st 3 ceramic cluch works well, and a moser 12 bolt. So far so good on wood.
Cam, is touchy. Stock will make power, depends what you want to do. Heads would make more differance then a cam. But cam is cheaper. I use a 222/216 563/563 116 lsa and it makes good power considering im at a 9-1 CR. seems most like the reverse split cam for turbos, Dont know if it works but it is popular.
Good luck.
Good luck.
