It's alive!!!!!! Again-until I decide to swap cams-again:crazy: http://i127.photobucket.com/albums/p...h_100_0618.jpg After finally finding time for my own car-I probably mulled over which cam, which heads, what compression for the last 4 months-then slowly but surely tried to perfect the install with getting the brackets perfect, intercooler perfect, everything! Just gotta get some paint on the pipes and shroud and I'll start doing some tuning with the SD setup this weekend. Then it's off to the track! |
sounds nice |
What all of those components did you ultimately decide on? |
Heads-AFR 225's Hollow stem intake valves, Cam-Big Compression-Lots :D |
small vacuum leak? ;) sounds awesome |
got crickets under the hood there sir! |
What exhaust are you running? Sounded so tame. Very nice to see and hear it running. |
| All times are GMT -5. The time now is 12:16 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
