tial 60mm gate issues
When i had what Tial called their 15lb spring setup.(Big light blue spring along with small dark blue spring. I saw almost 30psi.
Its actually only about 6psi of boost but I'm at high elevation. Those are MAP sensor readings, not boost sensors...
now i can finally start doing some logs... thanks everyone!!!!!!!! later on ill get boost controller working
my charge side is PT88 that uses 3" to the 24x12x4 core then steps up to 4" and into the 90mm TB
also using a Tial 50mm bov
also using a Tial 50mm wastegate
where is the boost reference line taken from? (for the wastegate)
and where is the boost gauge source taken from?
my wastegate is off the snail. i had to my boost controller but bypassed it to rule out that issue
boost gauge is referenced off the back of intake on the little nipple that is usually for the heatercontrols
as you go up in spring pressure the actual boost number would get higher and higher because of the increased velocity
