Rear main seal question and FI.
I have to put my ls1 back cover on my new 6. 0 engine. Can I just use existing seal car only has 12,000 miles on it.
I have read of the new seals having to be installed backwards to not leak in FI applications.
When did the new seals come out? So what rear seal and most of you fi guys running? Don't want to put this together and ruin my tex twin.
Should I go to other makes of rear seal?
Ive refitted the rear cover with OE seal installed many times.....damn, Ive wrecked too many engines
Never had any problems. If someone has told you to install it backwards, never listen to a word they say ever again.
Just lightly tap new seal into the cover until it is fully seated then you have to get the inner seal to slip onto the crank while you are sliding the cover into place.
Pfffff. I don't know what the hell people are doing to get the new seal to stay seated on applications that see ANY crankcase pressure. I personally believe it was a move to try to idiot proof installation.
Jim, you're thinking of the old style which would seat the seal into the crank harder with the crankcase pressurize... My PERSONAL experience is that the new seal (when installed as per instruction) blows up like a skirt in the wind even when well ventilated.
