LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Fueling & Injection (https://ls1tech.com/forums/fueling-injection-8/)
-   -   Will 160's be enough (https://ls1tech.com/forums/fueling-injection/1040626-will-160s-enough.html)
sevanseriesta Dec 30, 2008 05:37 PM
I used the fuel injector sheet above, but I was not sure if it is different for low Impedance Injectors. My goal is to make 1300 rwhp. So I put 1500 bhp in there and it says that I need 150lbs a min.
Again just trying to confirm that low imp and high imp use the same chart.
Thanks in advance!
Professor_speed Dec 30, 2008 06:13 PM
This what I come up with
Fuel Injector Worksheet
Actual Desired Crankshaft Horsepower B.H.P. 1800
Number of (same size) injectors to be used 8
Brake Specific Fuel Consumption desired 0.65
Maximum Injector Duty Cycle you will see 80%
System fuel pressure @ fuel rail 58
PSIG
(Static flow) injector required @ test PSI of 43.5
158.32 Lbs/Hr 1664 CC/Min
Shawn @ VA Speed Dec 30, 2008 06:28 PM
i have made 1100whp with 96's and 2500bhp with 160's.They will be more than adequate.You could use 120's with the right fuel pressure and regulator
Adam Connell Dec 30, 2008 07:09 PM
I have been talking with a few e85 guys and it's looking like we can see upwards of 1400fwhp with E85 and the right fuel pressure using 160s, but they will be almost maxed out... I think he was around 1200fwhp at 80%DC . Remember E85 takes 30-40% more fuel than non alcohol gas...
I have heard of there being 210s in the bosch style as well, but I dont know anything about them...
sevanseriesta Dec 30, 2008 07:53 PM
Thanks very much, thats what I wanted to know.
Old Geezer Dec 31, 2008 08:41 AM
"I have heard of there being 210s in the bosch style as well, but I dont know anything about them..."
I had 2 sets on the bench, and found them to be at least 210.. Closer to 230#.
Story I heard was, they were not supposed to be sold, but got here anyway. Supposedly no longer available. They were in the $850/set price range. Last set I saw were $1200.
FICINJECTORS Jan 1, 2009 11:22 AM
This is true about the 210's.
And the 150's are now also discontinued and selling for a VERY high price at most places (read $200 per injector)
We still have a couple sets and have them for $79.95 each flow matched.
~Rich
sevanseriesta Jan 1, 2009 11:46 AM
When you say the right regulator is there a special one. I am using an areomotive one right now. It is also the vacume regulated one also. If I can get away with 120's I would love to
Does anyone have any that they want to get rid of!
onfire Jan 1, 2009 12:41 PM
I'm running 120's +1000rwhp (T400 automatic) with a weldon regulator(best imho) and the duty cycle is in the low 60's at 55psi base pressure ramped up with boost 1:1. 120's are a great street/strip injector.
Shawn @ VA Speed Jan 1, 2009 01:54 PM
When i say correct regulator i mean a rising rate regulator.The 120's will easily supply enough fuel for your hp goals
sevanseriesta Jan 2, 2009 09:11 AM
Thanks, again
sevanseriesta Jan 2, 2009 05:51 PM
Who did you end up going with on your injectors?
onfire Jan 2, 2009 07:22 PM
At the time I bought them only Racetronix carried the Standard brand injector in a 120lb.
sevanseriesta Jan 2, 2009 08:27 PM
I bought the Trick Flow ones from summit. I could not really beat the price for 400 shipped.
© 2026 MH Sub I, LLC dba Internet Brands
