Fuel Problems, Help??? I have a 98 Camaro. I started it up and let it warm up for about 5 minutes or so then it started cutting out like it was out of gas, the car died and I havent been able to start it since. Any Ideas? And Yes It Has Gas In It... |
check the fuel rail pressure with a fuel pressure gauge. possibly a clogged filter or bad fuel pump |
I can push the nob on the fuel rail and nothing comes out, I unhooked my fuel line before the filter and nothing comes out. I have a 99 Camaro and I took the fuel pump off it and put in my 98 and still nothing. I even switched the fuse for fuel pump......Any other ideas? |
If there isn't any fuel squirting out when you push the schrader valve in after you have turned the key to the on position, then you have a fuel related issue as to why your car won't start. When you turn the key, the pump should prime and give you fuel pressure. |
Yes I Know Its Fuel Related, Im Just Wondering If I Need To Spend Money On A Pump Or If It Is An Electrical Problem. Im Not Sure Because I Swapped Pumps Already (As Far As I Know It Was Still Good) And Still Nothing, What Fuse Or Fuses Could Cause This, Other Than The Fuel Pump Fuse Of Course. |
Not sure, I think there is a fuel pump relay though. |
^^^there is a fuel pump relay |
Where Is The Fuel Pump Realy On A 98 Camaro? |
think its on the interior on the drivers side behind the kick panel |
NOPE, Tried The Relay And Still Nothing. Any Other Suggestion On This One??? |
fuel pump may have taken a crap. happened to mine when i ran it out of gas. do u hear the pump priming when u turn the key? |
Nope, All I Hear Is A "Click" I ordered a new pump, it should be here today or tomorrow. Ill let you guys know if that fixed it. I just didnt think it would all the sudden go out like that. We'll see... |
© 2024 MH Sub I, LLC dba Internet Brands
