Bosch Injectors
Bosch Injectors
Will these bosch injectors (part # 280 150 839) 160lb injectors work for my 408? I'll be boosting roughly 15psi regularly, maybe pumping alcohol up toward 20psi, we'll see when we get it running. These are high impedance, what do I need to make it work? Thanks fellas!
Tony
I was debating these for cost and running e85, but not sure on injector size for pump gas only, suggestions?
72lb Lucas Injectors high-impedance and rated at 43.5psi fuel pressure
@ 60psi fuel pressure, they'd be the same as having 84lb injectors, which would get me well over 800whp @ 80% duty
Tony
