Fuel System Suggestions
Just dropped a forged iron 370 in my 02 Z28. The motor is set up for a ProCharger (D1SC). What do you guys suggest for a fuel system (pump's to injectors)? 14-16 lbs of boost. Thanks for any help.
I would do the dual 255 intake pumps their's a write up in the stickies... You can probably get by with 60lb injectors with that setup... I am running the same thing you are and my injector cycle duty is around 80% but I still need to lean the car out....
