A1000 Question When I drive on the hiway for an extended period (20 min) my fuel pump is much louder than when I am cruising around in the city. Is this normal? |
I read something in the owners manual today about that, if you still have yours you may want to check it out, it says something about a voltage regulator, and what size tube you should be using if running pump for more than 30 min |
It is not designed to be consistently run. There Voltage regulator helps but it still is not a very good street pump. There are much better pumps to run fro daily street driving. |
what external pump would you go with for 1k wheel turbo car |
MagnaFuel |
this is going in a ls1 fox. pm me what i will need also need rails and i think i found some 103lb injectors |
© 2024 MH Sub I, LLC dba Internet Brands
