How often to change fuel filter?
Old Dec 18, 2003 | 07:52 PM
1320_PERFORMANCE's Avatar
Default How often to change fuel filter?
My z just turned 11k miles and was wondering how often the fuel filter needs to be change and if fram is alright as a replacement .
Old Dec 18, 2003 | 07:53 PM
sawedoff's Avatar
You are most definitely up for a change. It's every 10,000mi., with a street car.
Old Dec 18, 2003 | 10:26 PM
Thanks.
Old Dec 19, 2003 | 10:05 AM
sawedoff's Avatar
Originally Posted by BULLITT
are you sure about that? I think i'm only supposed to change it every 25,000-30,000 miles.
Yes, even the manuals state this. It's really preventitive maintenance, because you couldn't begin to imagine the crap and debris that's in pump gas; water, dirt. Who knows what else. With performance machines like these it only helps, and it's pretty much doctrine.
Old Dec 19, 2003 | 07:10 PM
Colonel's Avatar
If you run some bad gas through your filter then it could need replacing at 500 miles. If all of your gas is extremely clean then it could last 100,000 miles or more.
Personnally, I change them when the fuel rails start to see a drop in fuel pressure...which can turn out to be seemingly never in many cases. But, not everyone rides around with Autotap running in their passenger's seat and a pillar mounted fuel pressure gage staring them right in the face.
So, if you're not so **** about keeping tabs on every single little aspect of your car (like me), and as cheap as fuel filters are, why not change it every 10,000 miles whether it needs it or not? (Sawedoff, I'm agreeing with you again. .)
FWIW, my '01 Suburban has over 60K miles and runs great with the original filter (I'm not suggesting for anyone to run one this long. It's just that I like to experiment.) My '02 Z28 has 28K on the original filter and has shown no drop in fuel pressure to date. Based on past experience, I doubt there will be any within the next 100,000 miles, but then again, I could get a bad tank of gas tomorrow. It just depends on how clean your gas is...much like with air filters. Live on a dirt road? They won't last long.
Old Dec 19, 2003 | 07:26 PM
Jpr5690's Avatar
i go with 10 k
Old Feb 6, 2004 | 08:54 AM
jtc02Firehawk's Avatar
Question
What is a good brand to go with for a fuel filter?
Old Feb 6, 2004 | 10:49 AM
Mean Machine's Avatar
i use the kind that autozone carries. i think it's some german name. i recall buying a fram fuel filter and it wasn't the right size. perhaps they've corrected this by now.
Old Feb 15, 2004 | 12:23 AM
sercastiK's Avatar
do not buy the cheap kb or kw whatever the **** brand i had one of those filters **** up internally, now i only run ac delco or fram...i also agree with every 10k...
Jeremy
Old Feb 15, 2004 | 10:16 AM
Got Me SOM's Avatar
i'm overdue for one. wonder if this will help pick me up any mph.
