Quick question on install of Siemens 60lb'ers
I'm swapping the stock injectors out for a set of Siemens 60lb'ers for my Procharger build, and I'm not sure which groove (on the injector itself) the clip that holds the injector to the fuel rail should fit into. There are two grooves on the new injectors...I clipped about the first 3 on the top groove, but then got to thinking and I don't want to mess this up...
Will it be OK on the top groove, or should I try to press the rail down further to get to the second groove?
