-8 Fuel Line Does this sound right?
im about to convert my system to a return style, here is what i come up with...
Dual walbros y'd together with -8 bulkhead out of the factory sender
-8 line to the passenger side rail
-8 crossover
-8 out of the drivers side rail into a FPR
-6 return connected to the factory feed metal line
and the other outlet on the fpr blocked off
is this right or am i missing somthing?
-8 crossover
sounds like you are about to do this. it will work well
http://rides.webshots.com/album/64988796cazkku
make sure you give the walbros good power wires and solid frame or battery grounds
i have my regulator before the rails which is the optimal way to do it. mine has 3 ports. it feeds in one side and goes out the other side which then goes into the rails. the return comes out of the bottom of the regulator, and back to the tank.
and like mightymouse said, the ground is just as important as the power to the pumps
