What pump and injectors? - i need to give more information, because i am ready
Hey guys I am working on running 7PSI on a stock motor(might get 243 or 317 heads) which fuel pump and injectors do I need? (Turbo not blower if that helps)
Do you plan on upgrading in the future?
A single walbro 255 will work, I ran 2 255s in my car just so I have lots of room to grow!
Also a 42# injector will be fine as well, but again if you plan on going over 500whp I would go to 60#s just so you never have to worry.
Jay
Jay
42lb x 8 = 336 /.5 BSFC = 672 - at only 45psi if you jack the pressure up to 60psi then a 42 will support 776hp
external mount 255 walbro gs340m will support only 690 at 100% and 13 volts.
twins are safer - tons of fuel flow and good pressure is the best insurance one could ask for.
