Removing Fuel lines at the Pump?
Squeeze the plastic retainer clip at the end of the line together and pull. Should be all there is to it. I know that there on there pretty tight so you might need to multi task and squeeze with one hand and pry at it with the other with pliers or a screwdriver or something.
I have a real small pair of vice grip pliers that I can lock onto the clip to keep it open and then use both hands to pull at it with. Good luck.
I finally got it, thanks for the advice. I bought one the disconnect tools from advance and STILL had to fight with it. It was mainly because I didn't drop the tank and did the trap door. If I had been able to do it the right way, it wouldn't have been as hard with all that room to work with. I ended up still cheating and snapping off the attachments for the lines at the pumpso I could pull them out and have some room. So it worked out in the end.
