Dual Walbro Pumps - How To Get Rid Of T-Fitting
I need to get rid of the t-fitting that connects the twin walbro pumps in a procharged F1-C Camaro. It has become a restriction so I need to change over to a y-block. Just seeing what info was out there and if anyone had pics. It is a 01 so it has a plastic tank.
I am assuming a y-block wont fit in the bucket so I was planning on running 2 -6 lines up through the the top of the plastic bucket and getting rid of the stock plastic feed set up. Then connecting the two -6 line together with a y-block outside of fuel tank. Any suggestions?
Link to car:
https://ls1tech.com/forums/forced-in...c-build-5.html
Link to car:
Im sure you have seen this, correct? He uses a Y block from Home Depot.
https://ls1tech.com/forums/fueling-i...ick-cheap.html
Using a T in the bucket on my own car, fuel pressure fell up top when the car was at about 18-20psi. I never had it on the dyno at that level but seeing as it made 600rwhp at 10psi, it should have been around 800. That fuel system consisted of twin Walbros teed in the tank, primary pump had the straight through shot and they used the factory fuel port on top of the bucket (99-02 car) to a -6feed up to a the rails, Kirban regulator and evap line used as a return. Two meth nozzles from a cranked Alkycontrol kit.
Another car with the same fuel arrangement began losing pressure right at 800rwhp and was fixed by using two -6 feeds through bulkheads in the top of the bucket that went into a Y. It was never put on the dyno after but it ran another 5 psi of boost with fuel pressure still climbing afterward.
The car in question in the thread has the same fuel and meth arrangement as those two witht he exception of it's own -6 return. It very likely will make 800rwhp on it's pump gas tune. It's pressure stops rising up top and even driving the Siemens 83s static up top to see, the car still leans out at the very end.
Maybe I'm missing what you are saying though, do you use the fuel port or a T and a single bulkhead 90 on top of the bucket?
I have seen the dual pump write up for the metal tank and thought there used to be more pics and info on doing it in the plastic tank but now that I want to do this I have not been able to find anything. Can you just add a second pump off of a hobs switch and not make any changes to the fuel lines regulator or rails?
LS1TECH Sponsor
Can't compare your builds to mine, but I have proven over 1000rwhp multiple times through the stock tank connection & internal an t-fitting. Personally I feel you should be using a line bigger than a -6 to the front of the car..... it loses much more pressure/flow overall than the short piece of t/line in the tank at 800+rwhp.
There is no doubt the "T" is a restriction, but not the ultimate problem in a typical system. If everything else is up to the task, the "T" is not a problem. When other things are marginal, it can be the straw that breaks the camels back.
Also your base pressure & total boost referenced pressure makes a big difference to what the system is capable of. The overall combination is what makes or breaks the deal. Run big injectors & low pressure & you can make a ton of power. Recently had a C6 break 1100rwhp on one of my dual pump systems.
Lonnie do you have any pics of this set up? So the T-fitting is a -6 and the lines in the bucket are -6? Then this is connected to the stock outlet port on top of the tank? Where does it switch to -8?
