Injector swap question..
Old May 21, 2010 | 03:58 PM
BLUEBYU's Avatar
Default Injector swap question..
Probably wrong section....but anyway, do you have to remove the intake to swap the injectors.?
Old May 21, 2010 | 04:27 PM
supersick99z's Avatar
Not sure if there's room to get the rails off or not, but I would assume you could just unhook the stuff to them and they could be removed!
Old May 21, 2010 | 04:45 PM
sidewayz28's Avatar
no u do not..
just unhook the fuel line, unbolt the rail.. and pop it off. there will still be fuel in the rail.. soo.. just an FYI
Old May 22, 2010 | 01:14 PM
BLUEBYU's Avatar
Thanks.... probably just put a cap on the rail connection.
Old May 22, 2010 | 01:40 PM
01ssreda4's Avatar
4 bolts, 10mm that go straight down into the intake.
