Which 80lb injectors to use with vic jr?
Formerly Low_LQ4 - 6/6/10
Just as the title says what 80lb injectors are you guys running with your edelbrock vic jr intake and edelbrock rails?
I need injectors and harness adapters to run with the injectors.
Here are some pics of my injectors. Don't know what harness they use.
[/QUOTE]
![](http://i94.photobucket.com/albums/l89/dmc_racer/IMG00805-20100506-2356.jpg)
we have drop in 80's. and the wire adapters,
http://fuelinjectorconnection.com/sh...&productId=195
http://fuelinjectorconnection.com/sh...&productId=217
Those are the USCAR plug style injectors. The Siemens Deka 80's are available with USCAR or EV1 style plugs, so you can choose the style that matches your wiring harness without having to use adapters.
sorry but they are NOT UScar they are mini delphi exclusive to GM in all their trucks from 2000 - 2007 in 2008 they use he UScar plug. With one exception the trailblazer SS which use the LS2 car injectors . The 80 Siemens is 60mm tall o ring to o ring. The truck manifold is set up for a 46 mm injector. To use the Siemens you need to space the rail up 1/2 inch and use wire adapters on 07 down trucks.
