160's e85 power?
Old Nov 13, 2011 | 12:05 PM
ProTreeRacing's Avatar
Default 160's e85 power?
how much have yall made with them before they maxed out, and what pressure?
Old Nov 13, 2011 | 03:52 PM
FICINJECTORS's Avatar
hi, base pressure 43.5psi, 80% duty cycle on e85.
n/a around 1600hp flywheel
forced inducted around 1300hp flywheel
Old Nov 13, 2011 | 08:37 PM
so with a pressure at around 80~85 1500~1600 flywheel would be doable? turbo car
Old Nov 13, 2011 | 09:41 PM
hey,start at a base pressure of 70lbs you should be fine.
Old Nov 13, 2011 | 11:07 PM
Thanks, thats the information i was looking for, looking to do some 275 racing with a 88mm and the 160's on c16 are being a pain to idle, looking at making it idle better and be easier on the pocket!
Old Nov 14, 2011 | 01:50 PM
anytime.good luck with your build!!!
