school me on what exactly the vapor pressure sensor does...
this item here..... http://www.racetronix.biz/itemdesc.a...PS-F99&eq=&Tp=
![](http://i1206.photobucket.com/albums/bb453/BACKAGAIN74/Misc/aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa.jpg)
is it possible to delete it without harming anything or not?
thanks!
thanks!
Correct, all this does is periodically monitors if the evap system has a leak somewhere, common issue is if you forget to put your gas cap on. You will get check engine/trouble code if you delete, but there is a way to reflash the ECM to stop the evap code from going off
