ls3 top end fuel pressure regulator
what is everyone running as far as a fuel pressure regulator on a ls3 intake/
top end. im building a 370. with a ls3 heads and intake that i got stupid cheap since i work at a gm dealership.
[QUOTE=98cobrakiller;17483927]what is everyone running as far as a fuel pressure regulator on a ls3 intake/
top end. im building a 370. with a ls3 heads and intake that i got stupid cheap since i work at a gm dealership.[/QI'm running my stock fuel pressure regulator on my ls3.
Hey guys I did an ls3 swap on a 1999 trans am with what it seemed to have had a returnless ls1 fuel rail with a built in regulator (I just read that my car has the regulator on the tank ? I am confused because there is a fuel cap canister with a return line on my car
My car is dumping fuel out the exhaust (it did that before the swap which lead to ruining my ls1 block within minutes after rebuild) now if I don't have a regulator on the tank them I'm guessing the regulator causing the issue... But if I do have a regulator built in the fuel pump then I have another issue causing my engine to run rich on fuel (fuel pressure stays between58-60 psi and is steady
