Speed Inc now sells Squash Performance fuel systems!
Old 01-21-2014, 04:21 PM
Bryan @ Speed Inc.'s Avatar
Default Speed Inc now sells Squash Performance fuel systems!
Squash Performance Fuel System components, NOW AVAILABLE with FREE SHIPPING! Click the pic below to view their product line.
Old 01-25-2014, 11:32 PM
chrs1313's Avatar
Hey Brian I think you might want the first choice to be DW200 cause the walbro 262 is listed twice...
Nice setup for sure...
Old 01-26-2014, 12:03 AM
97WS6SCharged's Avatar
Very nice. Wish they made something for the 98 and older cars.
Old 01-26-2014, 06:29 PM
stealth355tpi's Avatar
What's needed for a wiring harness?
Old 01-27-2014, 04:36 PM
trans2000am's Avatar
whats the biggest pumps that can fit in these? currently running lonnies dual intank and the pumps are maxxed out- running c16 fuel
Old 01-27-2014, 05:31 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
I can up your pump size if you need more... no need to replace what you have.
Old 01-27-2014, 07:08 PM
sway99bird's Avatar
Nice !
Old 01-27-2014, 07:11 PM
No Juice's Avatar
Do you have any more pics of the sending unit ?
The pumps don't look like they are Y'd together prior to the top of the sending unit yet there are still only 3 ports on the top (feed, return, EVAP). Looks like there should be 2-feeds
Old 01-27-2014, 07:57 PM
sway99bird's Avatar
Why can't you get the Hobbs in the F-body pumps ?
Old 01-31-2014, 04:12 PM
No Juice's Avatar
ttt.....Bryan ???
Old 02-05-2014, 03:23 PM
whats the biggest pumps that you can fit? and turn around time once you receive the bucket
Old 02-05-2014, 06:53 PM
LS1TECH Sponsor
Please call me if you want to discuss in more detail.
Old 02-11-2014, 07:57 PM
LS1CALIBOY's Avatar
Does anyone know if you need to purchase a Hotwire kit for this setup?
Old 02-17-2014, 07:38 PM
No Juice's Avatar
Anyone...........anyone ???????????????????
Old 02-17-2014, 09:27 PM
realsquash's Avatar
Can I answer tech questions in here without problems with the mods?
The largest pumps it can take are two Walbro E85 400LPH pumps.
You can't run them from the stock wiring for sure. You'll need a couple relays and breakers, and the 2nd one should be operated from a Hobbs switch if it's a street car.
The pumps' outputs are merged together in the lid part of the unit so there is just one outlet port.
Old 08-15-2014, 03:21 PM
No Juice's Avatar
So how low can we safely run the tanks (just freeway cruising) with this kit since the bucket is gone ?
Also is it possible to get a -6AN on the return instead of the stock size ?
Old 08-15-2014, 04:02 PM
realsquash's Avatar
-6 and -8 AN are options when you order it... Safely you can go down to 1/8 tank or less when just cruising around. I wouldn't probably go that low when you're racing though.
Old 08-15-2014, 04:15 PM
No Juice's Avatar
It gives you the option for -6 or -8 on the feed but no options to increase the return side. Am I missing something ?
Old 08-15-2014, 04:42 PM
realsquash's Avatar
It's available with a -6AN on the return, and the evap can be -6, stock push connect, or plugged... If you want to order it just make sure you send them a note when you place the order and it will get done correctly.
Quick Reply: Speed Inc now sells Squash Performance fuel systems!
