Fuel pressure regulator not increasing pressure in boost?
My Aeromotive 13109 regulator does not seem to be raising fuel pressure in boost in a 1:1 ratio as advertised. With base fuel pressure set to 58psi, the fuel pressure at 10psi of boost is around 60psi. It seems to be doing just fine in vacuum though. I'm measuring the pressure at the fuel rail, the regulator is in the return line.
I have a Walbro 400 pump hot wired, so I don't believe it's a pump issue. Any thoughts?
Ah I see what you're saying, let the pump build up pressure and it should increase up to the point where the pump bypass opens up to relieve the pressure. If it doesn't build up pressure or not enough pressure then there is a leak in the pump or pump assembly. Is this safe for the pump?
