Fuel Gauge Won't Work!! NEED HELP!
Car is a 2000 Ws6 Trans Am, and as the title says i don't have a fuel gauge, I've tried a new cluster, and replaced the fuel level sensor on the pump and still nothing, is there anywere else that i could check? or anybody else experienced this???
Thanks,
Billy
Thanks,
Billy
not super familiar with you car but you could try checking the resistance in the wires that run from the sender to the gauge most are 0ohm empty 90 ohm full. If you have that at the tank then you know the sender is working.
just where I'd start with something like that!
