What size injectors for 600 RWHP NA?
1 Post
My 416 will make around 550-575 but I'd like some wiggle room. Thanks. MSD or FAST 102 intake with LS2 style rails.
Who told you that? The ls9/lsa/ls3 injectors are all externally the same. They all work with any head setup. The intake is what the injectors mount in and the only way that causes problems is with height. You will need height adapters and electrical adapters to run those injectors. Depending on what height adapters you need they will be 50-80 bucks and the harness adapters run 15-20 bucks for a set
1 Post
People use them on a variety of builds. The spray pattern may be different but its nothing a competent tuner cant handle with the dynamic control tables. There are many posts on hptuners that run them just fine.
http://www.hptuners.com/forum/showth...ons-for-an-LS7
http://www.hptuners.com/forum/showth...-LS9-injectors
http://www.hptuners.com/forum/showth...t-an-IFR-table
these are some i just pulled up on google.
1 Post
Everything I've seen seems to show a few guys arguing whether they will work or not. The reasons they list yay or nay are all in EFI tuner jargon that 95% of us including me don't understand.
well i just showed you a few threads with some of the top hptuners experts saying there are no problems. If i'm inclined to believe anyone its them. I prefer oem injectors as I know they were rated to go hundreds of thousands of miles with no issues not to mention they're very inexpensive in the world of aftermarket units.
at this point its up to you but i would not fear the ls9 injectors one bit. If your tuner knows what hes doing there wont be a problem. you can pm dstek on corvetteforum or hptuners forum he uses them regularly on all types of builds
1 Post
So I take it that spray pattern/angle isn't that important on a cathedral port?
I'm hoping I can get close to 600 at the wheels NA...but realistically I'll be somewhere between 550-580. Anything in the 52-60 lbs range at 58psi and will work in a FAST or MSD intake without spacers will work. I'll buy the appropriate fuel rails once I've found an injector. I'd like to stay with a newer style bosch injector. I'll consider the siemends/deka and the deatch werks since everything I've read on them is good; but only if I found a good deal on them used with low miles.
