4.8 turbo e85
4.8 turbo e85
Building a fox body ls 4.8 turbo swap, looking for fuel system advice. Using a fuel cell and external pump. I'm thinking an a1000 pump and efi aeromotive regulator, 80 lbs injectors, truck rails or aftermarket rails if I can find a ls1 intake for under million dollars. Shooting for 6-700 whp on e85. Is this a doable setup for the power goals and also street ddriving? Any other setups I should look into?
Update. I got a 03 6.0 now, s475 turbo ls1 intake with professional products fuel rails and I have magnafuel 4303 pump. Pump should be good for whatever I need. Next question tho what boost reference regulator should I look at? And I found a deal on 95lb injectors that were out of a lt1, would they work with. My rails/intake and would the connectors work? They. Are high impedance. Alsi
