5.3l turbo build... Injector help 5.3l S472 317 heads/ ls6 springs ls6 camshaft ls6 intake manifold HLY-12-1200 Holley Fuel pump Looking for injectors... shooting for 600whp Thanks in advance, let me know if you need anymore information. |
Go with the sieman deka (spelling?) 80# injectors. They are cheap, proven to work, and dead nuts reliable. Been pushed to 800rwhp with no glitches.. eBay is about the best place to buy. |
Originally Posted by JustAFooL
(Post 18693270)
They will work with the ls6. You will have to check on the harness, I would imagine the connectors are no different though |
If you are going with a custom PSI harness, you can have the injector connector made to match whatever the plug is on the injector. |
© 2024 MH Sub I, LLC dba Internet Brands
