Best priced reliable 96lb injectors out there. Need some advice on best deal on 96lb injectors for 6.0 turbo build. Lots out there cheap but don't trust without positive feedback. Thanks |
I use the Siemens Deka 80's, and run them at LS pressure. 4 bar. That's a 94+# flow rate. They are hi imp, so they work w/o a box. |
Best priced reliable 96lb injectors out there. That was also another question. I've heard different high/low impedance stuff but I'm running oem pcm so I'm guessing staying with high will be best idea. What's best source for those? ? |
Best priced reliable 96lb injectors out there. Also,tunet suggested 3 bar map. Are you suggesting 4? |
Best priced reliable 96lb injectors out there. Oops,tuner |
© 2024 MH Sub I, LLC dba Internet Brands
