00 camaro won't stay running codes p0171 and p0174
It won't stay running and codes are p0171 and p0174 and just did the fuel pressure at the testing port and its 15psi and I believe at turn key it should be 40-48psi so the fuel pump needs to be replaced?
Thanks everyone
Thanks everyone
Just got the car up on the lift checked the fuel filter and replaced it so I looked at all the feed lines front to back no kinks so I'm going to make an access hole to get the pump out for further inspection
