Bad check valve
Old Nov 7, 2015 | 06:31 PM
Stroked 388's Avatar
Default Bad check valve
What kind of problems can I have with a bad fuel pump check valve
Old Nov 7, 2015 | 06:58 PM
MY_2K_Z's Avatar
Pressure bleeding down while not running and losing prime causing you to have to reprime every start up.
Old Nov 7, 2015 | 07:01 PM
Is that the only problem I could have. Reason I ask is because I over fuel at a idel and lean out when I get on it.
