best injectors/rails/fuel pump for H/C/N02 setup
What would be best (not overkill) but doable set up with the fuel rails, fuel pump and what lb injectors with 243 heads, stage 3 cam and 100-150 wet shot. I'm trying not to go with a stand alone fuel system but if necessary I will.
Im asking because of the entire set up I'm going with not just for the spray. Figured if I'm pushing that much more power with every thing bigger injectors would be necessary and maybe rails too.
I'm in the same boat needing the same parts. I have read many say to get 42# injectors. My question is where can you get them for the best price? And is there any other options? I have no problems repinning connectors. My main concern is that the tuner won't have issues, and that the oe fuel rails will still work. What have you budget hotrodders came up with? Thanks!
