E85, questions.
E85, questions.
What do I need? Just injectors and pump? Who sells the parts? Is there a direct replacement pump for my 2000 Chevy ck1500? Planning on running only e85. Thanks
Technically you should run a pump and injectors that are E85 compatable, although I know people who dont. Try calling Lonnie's Performance. They were very helpful in explaining this all to me
I didn't even realize that companies sold kits without intercoolers anymore. You'll most likely see a massive gain with ethanol.
What's your current pony power? How much boost? Supercharger size? Etc?
You could probably get away with LSA/LS9 injectors, but I'd go with a 60lb just to be safe. You'll need a 340lph pump as well. Make sure whatever you buy is ethanol compatible.
