Aeromotive FPR work like this??
Is their any reason running my new FPR will be an issue routes like this? Alternator is mounted in passenger side head and gives me limited ways on doing what I originally had planned. It's the second pic down with no return line coming TO the regulator.
Either is perfectly fine.
BUT, for the dead end rails, do keep the regulator as close to the injectors/rails as possible.
The further away it is, the worse a dead end rail setup becomes.
The return system circulates fuel through the rail and cools the rail and most importantly purges any air bubbles from the rail.
In the dead head scenario air bubbles in the rail have to leave via the injectors displacing fuel.
The rails do not need cooled, fuel gets used by the engine so cool fuel still flows through the rails.
And I've never had a scenario where air bubbles have been any issue....how would you even know ? and where have these air bubbles came from ?
OEM's now run their rails dead end on millions of cars, none of what you are saying is a problem.
I've 2 rails flow through and 2 rails dead on on my own car, never had a problem in some 7-8 years like that.
Really, either option is fine abiding by what I stated already. But yes a flow through and regulator after the rails/injectors is generally preferable but in no way whatsoever essential.
The further away from the regulator, the more chance of a pressure disparity between the regulator and the injectors.
ie have no hose attached to your water tap and water flies out.
Attach a 100ft hose to it and it turns into a trickle. Same "pump" same base pressure . It's just easier to push through a shorter hose.
Obviously 100ft is never going to happen on a car but you get the idea, and it is also dependent on fuel line sizes. A small line will show problems sooner than a large line.
With oversized lines it may never be a concern on a car, if lines are anywhere near the limits of the system, then it can become a concern sooner.
But all of that is pretty much common sense and applies to any fuel system.
-8 is plenty.
The only thing I'd say about the reg pre rail setup, is when monitoring fuel pressure, always do it at the furthest point on the rails. Not at the regulator.
But if all line sizes etc are a good size, then there should be negligible difference between the two anyway.
