5.7 turbo fueling questions
Im putting together a small turbo build in my 02 camaro.
Im going with the CX Racing A/C kit and an on3 76/65 turbo.
Im all set on the turbo side of things.
Im kind of clueless on the fuel side of it.
Im wondering what has to be changed, bare minimum. Im only looking for 450-500hp
I already know ill need a fuel pump and bigger injectors.
Can you use stock fuel rail, lines, regulator, etc?
Not totally clueless, just not sure what stock parts will work.
Thanks!
Thanks!
From what i understand the stock lines should support about 500ish. im in the process of a 5.3 turbo build myself, id recommend doing a external regulator so it can reference boost and increase pressure accordingly
