Racetronix fuel pump question
so i just have a basic question. I just ordered a racetronix fuel pump with hot wire kit.
http://www.ws6project.com/user_stor/...3a24de384556c7
this one to be exact just wanted to make sure i didnt need anything else to install. Dont want to have to wait longer once i get it to install and have everything running good..
when you receive your order from ws6store, id create an account on racetronix.info and post in the appropriate subforum and confirm that what you received is correct.
the reason i say this is because the guy at ws6 store (mike?) made an honest mistake and sent me the wrong in tank wiring harness which in turn made the fuel pump pump fuel back into the tank as opposed to towards the engine like it should. i initially did not do the trap door mod but i was not going to drop my rear and gas tank twice, so i cut the hole, fixed the wiring issue and moved on down the road.
