in-tank fuel pressure regulator
Hi,
I need a replacement in-tank fuel pressure regulator for a 2000 camaro. it has a racetronix fuel pump kit but the fuel pressure is bleeding off after initial key on and is causing a hard start/long crank problem.
does anybody have the GM part #? thank you.
I just went through this. I thought the same thing. It turned out that the clamps on the hose from the pump were leaking. The only way to tell is drop the tank down enough to pull the pump out enough to key on. I changed to a compression clamp and it still leaked so I put two screw clamps on.
Good luck, its a pain in the ***.
