2002 Transom Fuel System Change , now car bucks?
So I changed my fuel system out the other day and also reconfigured my catch can. The car starts and runs but when you get on it, it doesn't do anything bucks and stalls out.
Could this be because of the new fuel system? Fuel Pressure stayed the same. Or could this be because i reconfigured the catch can vac line routing?
Let me know what you think.
Thanks!
Thanks!
Changed the feed and return line to a smaller line that is ptfe. Changed the tank back to the stock tank with a squash performance setup instead of a fuel cell with the magnafuel 4301 pump.
The regulator, rails, etc stayed the same.
The secondary pump is run off a Hobbs switch which now comes off of where the Mighty Mouse pcv was hooked up off the manifold. Now a vac line is hooked up which goes to a vac block and the pcv is hooked up to that vac block as well as the Hobbs switch.
When you say it sounds like air what do you mean?
