4 port inlet FPR recommendations
I'm doing a fuel upgrade and plumbing a 4303 with -10 to the engine with a billet -10 adapter to four -6 outlets to the four -6 rails on my engine. I'm looking for a regulator with four -6 inlets with a -8 retur
I found a magnafuel with four -8 inlets and single -8 return, but not seeing much else out there. Anywhere I can look and anyone know of something? Needs to be boost referenced
Restricted User
You can get -8 O-ring fittings that will have a -6 male end on them.
You can also get -6 female fittings that fit a -8 AN hose.
Either way, you can make a -6 AN setup work with that regulator.
I got the pump and magnafuel 4 inlet regulator. Placing the regulator, just how important is the length of each line? I could have up to 10 or so inches difference in length for one side to the other
I don't think I'm going to worry about. The regulator will most likely end up on the firewall and since the regulator body itself makes it one large system, have small variations from the front of the manifold to the back won't matter at all
Funny you mentioned that. I bought some -6 to -8 Y's and am running two single lines back to the regulator The Y is parallel style and cleaned things up quite a bit. I'll post some pics when I get farther along
