Fuel line and fuel rail plumbing
Need advice guys.im going to be installing a magnuson heartbeat supercharger ,it uses a stock ls9 fuel rail that only has a fuel in but no return..I currently have a fuel line and return line plumb to my engine bay of my 68 camaro.i also have a aremotive fuel regulator 13110.trying to figure out the proper plumbing .does this diagram look like it will work or what's a better way?
This system will work fine. Then only issue I see is I have a similar setup in my car with the same regulator and my regulator does not hold pressure when the fuel pump is turned off. So if the engine his hot and the fuel pressure bleeds off the heat from the engine can vaporize the fuel in the rail and cause it to loose prime. Then the vehicle will crank for a while before it starts to re prime the system. I contacted Aeromotive about this issue with the regulator and they do not design the regulators to seal all the way with the pump off. Other than that the system works great.
