Need Help Spec'ing Injectors! In here.... I am building a 69 Camaro with a LS1 out of a 2000 SS Camaro Stock internals cam is COMP 227/236 - 614/621@111lsa 108CL heads are factory 243's milled .015" Factory LS6 intake I need suggestions on injectors and where to get them. I bought a set 5 years ago or so from Five-O Injectors and havnt called them yet but figured I would see what the consensus says on here Thanks |
Hi Brian :321: I have nothing important to add, but I'd say you'd probably have more than enough injector with some 36-42#ers. Check Fuel Injector Connections website. |
Originally Posted by zachm89
(Post 19562265)
Originally Posted by 2BFAST
(Post 19562281)
Zach! Yeah, just looking for some suggestions on an exact what I should be looking for. So many options. Any injector that flows more than what you need will work. Get some 42s or larger if you want some headroom. |
(Post 19562252)
| All times are GMT -5. The time now is 02:40 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
