fuel sending unit?
Old 04-27-2017, 10:39 AM
Allstock02's Avatar
Default fuel sending unit?
my gas gauge is all over the placing, I'm assuming its in the tank seems like a common issue, my ? is can I just replace the fuel sending unit or do I have to buy the whole pump assembly? also what brand is I need the whole thing?
Old 04-27-2017, 10:41 AM
Received 3,021 Likes on 2,352 Posts
You might want to check any ground related to gauges. A bad ground can really make gauges go all over the place.
Old 04-27-2017, 11:47 AM
Allstock02's Avatar
don't the gauges use ground for signal?
Old 04-27-2017, 12:48 PM
Whether they do or not, a good connection is still needed.
Old 04-27-2017, 12:51 PM
Allstock02's Avatar
I'm pretty sure its n the tank, I will check the wiring later just need a answer if the whole pump has to be replaced that's all.
Quick Reply: fuel sending unit?
