Finding correct fuel injectors for my 5.3L LS Engine
Old 08-03-2017, 09:45 AM
jgreco23's Avatar
Default Finding correct fuel injectors for my 5.3L LS Engine
I bought a 5.3L LS engine to rebuild. It was from a 2002 Silverado truck. I plan to install it into my '72 Monte Carlo, so I had to purchase an auto intake manifold to maintain hood clearance. I bought a manifold with injectors on eBay which described it as off a Camaro. It had Bosch 0 280 155 931 injectors, all with bad o-rings and two of the injectors are damaged. I need to know what injectors I should purchase or if these Bosch injectors are ok (and I only need to replace the two damaged ones).
Old 08-03-2017, 11:43 AM
Restricted User
JoeNova's Avatar
Just get the same injectors. The cars have different length injectors than the trucks, so you'll need to get ones intended for the car intakes.
Quick Reply: Finding correct fuel injectors for my 5.3L LS Engine
