fuel injector selection and fuel pump relay
first: i need HIGH impedance injectros, avoiding to use the driver box. need to be E85 compatible and have proper data for GM ecm. (02 fbody)
i was informed to stay away from HPI injectors bed reputation apparently, (wrong data), deka 80s are affordable but might max out, what are the best bang for the buck?
i can use the bosh 210 and cbm adapters to have them measure 60mm length. Is this too much for a street car i plan to run pump gas, and e85 for . theres few part numbers for these? any way to avoid knockoffs?
another option is bosh 160lbs #0280158827 which i heard people have had issues with operating temperature rising ? i plan to use billet fuel rails.
bosh120?
fic 127?
second :
im looking for options, will be running a dual pump set up. 8an feed 6an return, fpr. i want to build my own relay will this type of relay be ok?
thank you
bosh120?
fic 127?
second :
thank you
Restricted User
They are on FIC and TSP websites. These are great for LS1/fbody guys because they are stock injector length and plug right into our harness with no adapter.
https://www.texas-speed.com/p-3976-f...injectors.aspx
https://fuelinjectorconnection.com/p...high-impedance
And as a tidbit of info, they ARE actually shorter injectors, the bottom colored sections is an aluminum extension added on to make them stock length.
Here they are next to a truck injector
