Fuel rail set up, ls3 top swapped lq9
Hello all, i just have a quick question about my current build. I just swapped an lq9 into my 01 camaro, and am doing an ls3 top swap. I know that the ls1 style rail will not fit onto the ls3 intake, so my question is can anyone help me with choosing a fuel rail set up. I was thinking about a fast fuel rail and fuel line set up, and installing a fuel pressure regulator on the rail that way, but then i dont know what all hardware and which f.p.r to get. Any insight would be helpful. Thank you.
How much power are you after? If not much more than 500, the stock setup will be more than enough, and are easy to find.
Yup. Sure can!
I was figuring he would find a used one for a bunch less.
I DO know watcha mean! But I figure it has to work once in a while.... lol
Hey, ya never know for sure....
I don't think the FAST rails will work with factory LS3 intake, but only works with their intakes. The Holley rails are a good value, look nice, and should handle anything you want to throw at it. I'm running them on my swap.
