fuel pump on a stick
Hi,
I am contemplating purchasing the new Holley 12-300 "fuel pump on a stick" for my LS1 swap in my '68 camaro and was wondering if anyone has used it or can give some feedback. It fits in the original gas tank and has the pump, regulator, sending unit and hydramat all in one. According to Holley, it doesn't need a return line. The Holley tech said all you have to do is install it in your original tank, run one line to the front and you are done. Sure sounds easy. Thanks in advance for any feedback or responses.
Richard
Richard
If it's as good as the stuff Holley has recently come out with, it should be excellent. It's so new, though, there might not be too many using it yet.
The only Holley products that I have purchased/used in the past was the LS swap into 1st gens conversion kit including headers and oil pan and I have to say, I am very well satisfied. Everything went together very smoothly with plenty of clearance.
