Calling Racetronix...or anyone who might know
ws6 store says none available ....emailed lonnie....no reply yet
went to the GM dealer down the street from me.....fuel pumps are not a separate available item.....however if you need the lower half of the bucket it is available
guessing GM wants you to buy a new bucket every so often to replace all the internal parts that are not available separately
a new bucket from delphi is 250$ off rock auto
is the racetronix kit compatible with a new bucket ?
I thought that he would.
Did you suggest to him to keep these as spares when he does conversions to duals or larger pumps so he can resell to those where the stock one has failed?
Good to hear that you got what you needed.
Lonnie stepped up to the plate and sent a couple of used ones to the OP.
Originally Posted by dlandsvZ28
It's not that the sleeves don't fit. Its that after twenty years of being in gasoline the the stock sleeve deteriorates and can't be used leaving the pump just hanging in the fuel module when upgrading to a larger or more efficient pump (larger capacity - not necessarily larger dimensions). Apparently the rubber form fitted stock sleeve can't be replaced. Only option is to find a used one.
#33
