Racetronix 340 / c5 fpr help
a few questions, I’m installing the corvette fpr and the installation instructions say to remove fpr housing out of the bucket to install a clear hose to fill the bucket. How does it come off? I’ve tried to spin and and pull it.
This is the housing. I’ve removed the fpr.
im missing the blue clip that is supposed to retain the purple fuel lever wires into the new harness. Is it necessary? Is it discontinued from the kit?
I have two of these hoses. One end should fit on to the fuel pump, but as you can see from the photo.... the barb is larger than the hose. Do I not have the correct hose?
